Converting an Austin Seven to 12 Volts
All those in favour?
The strongest argument for converting an Austin Seven to 12 volts is practical: it offers more scope to equip the car for regular use, particularly after dark. In Austin Seven Friends discussions, owners repeatedly mention better lighting, brisker starting and the convenience of using readily available electrical components. These are worthwhile advantages for a frequently used car, even if they matter rather less to one whose outings are confined to fine Sunday mornings.
The electrical advantage is straightforward. For the same wattage, doubling the voltage halves the current: a 60-watt lighting load takes 10 amps at 6 volts but only 5 amps at 12 volts. This is useful because the Seven's enclosed dynamo has limited cooling, and heating in its windings increases with the square of the current. As 12 volts is twice the 'pressure' of 6, voltage drop is reduced as it copes better with aged connections and an earth return through a body shell.
A properly arranged conversion therefore supplies comparable lighting with less current, or more lighting power without demanding a corresponding increase in current. Mike Sharp's article, reproduced by the Dorset Austin Seven Club from the Pre-War Austin Seven Club magazine, identifies this as a principal reason for converting. It does not, however, give the dynamo unlimited capacity; the charging rate still needs to suit the particular unit.
All those against?
I take the view that, unless you are driving more than 4,000 miles a year, a standard dynamo in good condition, running at 6 volts, is all that's required. From direct experience, when I was covering between 15 and 20 thousand miles a year in the 1960s and early 1970s, a properly rebuilt dynamo would need new brushes only every 25,000 miles and last without further trouble to 75,000 miles. In other words, it's likely that only your grandchildren will need to repair it.
"But the dynamo output only 8 amps. How do I cope at night or in bad weather? You may ask.
If your Seven has an all-LED-bulb set-up, the dynamo will put a charge into the battery with everything switched on. Typically, with LED headlamp 'projector' bulbs fitted, two LED tail lights and an electric wiper motor running, a 2 to 3 amp surplus will still be available. One tip on a 6-volt system for improved performance is to earth everything direct back to the battery. Another option is that, with LED bulbs, owners have found that it's possible, with all the lights on, to reduce the maximum dynamo charge to four amps with only a slight discharge; ergo, the dynamo will run cooler and so should last longer.
TO THE JOB IN HAND
To run on 12 volts the dynamo does not need rewinding
First, there is no need to rewind the dynamo; if it is no longer constrained by the fitted battery, it can already produce more than 30 volts.
One thing to bear in mind is that, when using the original 6-volt dynamo on a 12-volt system, the engine will need to be turning rather faster before the dynamo begins to charge. The dynamo can be rewound to improve its 12-volt output at lower speeds, but that is by no means essential.
I spoke to a very experienced friend who converted his Seven to 12 volts more than 30 years ago and uses the car almost daily; the higher cut-in speed has never caused him a problem.
How the battery controls the voltage
The original Austin Seven three-brush dynamo is arranged to produce a more-or-less predetermined current, rather than a fixed voltage. As its speed rises, the voltage will rise as necessary to drive that current into the electrical system. When a battery is connected, its voltage effectively clamps the system to something reasonably close to the battery voltage.
If, however, you disconnect the battery while the dynamo is charging, the voltage can rise alarmingly. This is not a useful experiment to conduct, unless your interests extend to blown bulbs, damaged electrical equipment and the possibility of melting the soldered connections in the dynamo.
The simplest conversion
Apart from changing the battery, bulbs and other voltage-sensitive equipment (though the starter motor can be left; they are know to service perfectly well on a 12-volt system and turn the engine over much more energetically), the main alteration concerns the charging control.
The simplest approach is to retain the original three-brush arrangement and modify the cut-out appropriately for 12-volt operation. On the CF1 cut-out, for example, the 6-volt shunt winding is about 33 ohms, so approximately another 33 ohms can be inserted in series. This keeps roughly the same current flowing through the winding when it is operated at 12 volts. Similar modifications are described for the CFR and CFR2 units.
This has all been done many times before, and the Cornwall Austin Seven Club describes the procedure here:
There is a rather better way with a voltage regulator.
An improved conversion is described on the Bristol Austin Seven Club website and, to my mind, it is the neatest conventional solution. The dynamo is converted from three-brush to two-brush operation. The third brush is removed, and the field connection that formerly went to it is connected to the earthed main brush.
Control of the field current is then handed over to a proper voltage regulator, rather than being determined by the position of the third brush.
What the regulator does
The Bristol article describes using a 12-volt Lucas RB106 regulator. This gives the sort of charging behaviour taken for granted for many decades: after starting the engine, or when the headlights are switched on, the dynamo can provide a healthy charge.
As the battery becomes fully charged, the regulator reduces the dynamo output accordingly; the battery is not boiled dry, and you have another 0.109 b.h.p. to play with.
Keep the current within the dynamo limit
There is one important qualification. The Austin Seven dynamo is still an Austin Seven dynamo. Fitting a regulator does not increase the amount of current it can safely carry, so the regulator's current limit needs to be appropriate for the dynamo (no more than 8 amps), rather than simply left at whatever figure suited the much larger car from which the regulator specification originated.
The Bristol conversion is described here:
The result
And that is essentially it. The dynamo does not need rewinding simply because it says '6 volts' on the tin. It is already perfectly capable of generating 12 volts and considerably more. What needs changing is the way its output is controlled.
Bingo. You now have something approaching a modern charging system, while retaining the original Austin Seven dynamo. Which is probably modern enough.
