Cazeneuve Lathes - Page 2
Cazeneuve Home Page   Model HBX 360
Early Cazeneuve Lathe  Model L.O.   Cazeneuve Factory
A comprehensive Operation and Maintenance Manual and Parts List
is available for the HB500, HB575 and HB725 Models and for the 360-HBX as well as other literature
Some other high-precision French Manufactured lathes
ARS   Aero   Carteron   Cazeneuve   Haulin   Jenny  Manhora
Precis  Prudor   Strube  Vuilleumier Freres
Cazeneuve "Universal" hydraulic copying (tracer)  attachment that mounted on the HB500, HB575 and HB725. The unit was able to perform both longitudinal and traverse copying and was available with a variety of toolposts including a special high-accuracy 4-way type. A mechanism was incorporated that allowed a finish cut to be taken immediately after roughing was finished without having to remove or adjust any component.
Each unit was scaled for the particular lathe with slide travels of 96, 96 and 134 mm for the HB500, HB575 and HB725 respectively together with a common slide speed of 3 metres per minute
Multiple V-rope drive from motor to spindle
The headstock spindle was housed in a sleeve housing that ensured both a very high standard of alignment
and the facility to remove it and return to the factory for any necessary refurbishment
Micrometer carriage stop and the special metric-pitch thread-dial indicator
Chip Guard
A multiple-swivel light unit was available that bolted to the rear wing of the saddle
A special extended chuck backplate was used on the "semi-gap bed" lathe to
avoid the saddle overrunning the gap when working close to the chuck jaws
A slim, "Toolroom-type" hardened steel faceplate with circles of tapped holes. This unit allowed the maximum gap capacity to be used
Standard compound slide rest assembly with a rear-mounted T-slotted cast-iron block carrying a pair of toolposts for parting off and forming work
Rear-mounted hydraulic-driven tool slide
Front and rear-mounted hydraulically-driven slides
Double front-mounted toolposts and a rear-mounted hydraulic slide
Electric pump and coolant tank
Hydraulic copying attachment and tank
For ease of maintenance, the main switchgear was mounted on a handy, swing-out plate
Taper-turning unit - a quick-set type that was engaged and released by simply turning the knurled ring fitted to an extension of the cross-feed screw
