The Austin Seven Pearl Cabriolet - Page 2
Pearl Cabriolet Home Page  Pearl Cabriolet Mk.2 Review
Austin 7 Home Page
A Mk.2 Type ACA Pearl Cabriolet. Yes, it does look at a glance like Ruby, the artist having smoothed out the contours of the roof to an extreme extent
Here's an advertisement for the elegant Pearl that relied heavily on the language of sensation and comfort to make prospective buyers long for the pleasures of open-air motoring. "On a warm summer's day", "…all the benefits that fresh air and sunshine can bring", "How cosy and snug", and "proof against wind and rain". All carefully chosen phrases that, between them, managed to promise both the invigorating delights of fresh-air motoring and the comforting assurance that, should the British weather behave in its customary manner, the Pearl could be buttoned up against it.
An advertisement designed to stir the imagination and ignore the mechanical. "The road is yours!" one can almost hear it proclaim, in the crackly if splendidly confident received-pronunciation tones of a contemporary cinema travelogue: "With the hood folded back, the sun overhead and the Austin Seven Pearl beneath you, new scenes and fresh delights await beyond every bend. There are hills to climb, villages to discover and pleasant inns at which luncheon may be taken. One merely points the Pearl towards the horizon and departs."
A delightful picture of motoring from that curious golden age when advertisements confidently assumed that Britain enjoyed a Mediterranean climate, every village inn was run by a splendid fellow who served an excellent luncheon, and only to people like you. Not only that, but every country road had been reserved for those who had 'Invested in an Austin'
While not the most colourful or engaging advertisement, it does point out, for those who can summon enthusiasm for the less glamorous end of a specification sheet, not only the smoother three-bearing engine but also the removal of two long-standing Seven irritations. The rather sudden clutch engagement was cured by adopting a Borg & Beck unit, with greater pedal travel and much smoother take-up, while the Semi-Girling braking system at last allowed each brake to be adjusted individually.
The one thing still missing, and soon to become standard throughout the industry, was automatic regulation of battery charging in place of the rather crude manually selected high-and-low, or summer-and-winter, arrangement. The Austin Ten for the 1935 season, introduced in August 1934, included among its mechanical improvements 'automatic ignition and compensated voltage control', the latter also being fitted at the same time to Austin's 12.4 hp taxicab. Morris followed, with its catalogue for the 1935 season stating, "All Morris models from the Twelve Four upwards are fitted with compensated voltage control, which automatically regulates the dynamo output to suit the exact requirements of the electrical equipment."
Austin 7 Home Page
