Continued: Provided with two T-slotted wings towards its tailstock end and a single towards the clutch, the saddle was guided on a front Vee and a rear flat. Of double-wall design the apron contained gears of heat-treated nickel-steel with high-carbon steel shafts and a phosphor-bronze worm wheel to pick up the drive from the separate power shaft. Both the sliding and surfacing feeds were controlled by single-lever operated tumbler arrangement with a cam-locking action - interlocked, of course, with the clasp-nut engagement handle to prevent inadvertent simultaneous engagement and the resulting mechanical marmalade. The rack was of high-carbon steel, and the pinion which engaged it of heat-treated, nickel chrome-molybdenum steel. The basic machine was fitted with a simple 3-speed gearbox on the end of the leadscrew giving a choice of three sliding and surfacing feeds for each setting of the changewheels (with feed rates of: 0.030", 0.015" and 0.007" inches per revolution). To guard against over-enthusiastic use by inexperienced apprentices (or impatient piece-work operators) a pre-loaded slipping clutch was fitted to the feed shaft. The set of changewheels provided for cutting all standard English threads together with a 127T metric translation wheel A Norton-type, quick-change, screwcutting gear box was available at extra cost and this gave 32 feeds and threads - and was supplied complete with additional changewheels for generating metric pitches. The leadscrew was properly mounted in tension with ball thrusts at each end and cut to give a pitch error which did not exceed 0.002" in any 12 inches. A rather fine touch - and very unusual - was the provision of an additional support guide for the leadscrew immediately before it passed thorough the clasp nuts, a fitting designed to reduce both bending stress and wear A thread-dial indicator was part of the standard specification. With a 3-Morse taper spindle, the tailstock was the only part of the lathe to show any evidence at all of cost cutting, being provided with loose (self-hiding) spanner to lock it to the bed. A built-in, lever-operated cam-action cross-shaft would have been much preferable and could be provided - but at extra cost. Equipment provided with lathe when new was basic: stand with suds tray, a 4-way toolpost, a small faceplate, drive plate, travelling steady, a set of spanners and changewheels. Additional accessories such as chucks, a fixed steady, larger faceplate, taper turning attachment and electric coolant pump and suds tank could be supplied at extra cost. Following the example set by the Company's larger lathes, the "Junior" was made entirely of controlled-quality materials and constructed to Schlesinger limits of accuracy. All levers and handwheels were chromium plated and, to complete a sound, English-built job, the lubrication points were fitted with dirt-excluding nipples. Many years ago a friend of the writer found a "Junior" tipped upside down in a scrapyard. Although rusty and looking thoroughly dishevelled, the quality of construction was such that only a careful clean, adjustment of clearances, replacement of the odd broken handle and replenishment of oils was needed to put it back into daily, productive use.
