Weiler LZ-260, LZ280 & LZ-300 Accessories
German and English Text
Weiler LZ-260, LZ280 & LZ-300 Page 1    Weiler Home Page   Manuals for Weiler lathes are available
Weiler Home Page  Condor   Weiler Primus   Praktikant   Praktikus
Weiler LZ330   Commodor   Ergodor   Matador   220, 250, and 280 Series
The novel Weiler "follower-type" taper-turning attachment that left the standard cross-feed screw in place. The unit was replaced the standard cross slide and was, in effect, a replacement top slide with slideway adjustable to allow tapers up to be cut up to an included angle 30° and 300 mm long. The slide locking arrangement consisted of a plate bolted across the tailstock end of the bed connected to the slide by a steel bar. Although it was possible to leave the unit in place for ordinary turning, the makers recommended removing it to preserve accuracy for taper work.
Weiler milling slide and indexing unit
A small capstan head for mounting on a lever-action tailstock spindle. Useful for, simple, short-run production jobs.
