Brown Machine Company, Chicago USA
"Brown" and "Dandy" Lathes
Brown & Dandy Catalog 1937
Brown & Dandy Catalog 1940   Dandy Catalog 1940
Model P & Underdrive Photographs
Long forgotten until recent times, when two examples of its lathes were found, the Brown Machine Company of Cincinnati, Ohio, was founded in 1889 by John J. Brown and grew steadily through the succeeding 20th century. By 1937 the company had moved into a large new factory - the trading address given as 14-16 North May Street, Chicago, Illinois -  and by then was being run by Mr Brown's son, Thomas E. Brown.
When the company ceased production is unknown, but one imagines that, as an engineering concern, they are likely to have survived WW2 - but afterwards disappeared.
According to their sales literature, by the late 1930s Brown Machine was making a limited range of lathes including their top-of-the-range model the rather South-Bend-like Model "F", a backgeared 10-inch swing machine with a No. 3 Morse taper, 0.75-inch bore spindle running in Timken taper roller bearings, a quick-change screwcutting and feeds gearbox and mounted on an underdrive plinth in cast iron; astonishingly, not a single example one of this type has yet been found. The apron held the expected worm-and-wheel reduction gearing - driven by a key running a slot machined down the length of the 0.75-inch diameter, 8 t.p.i. leadscrew - that provided power sliding and surfacing feeds, the drive being through turn-knob-operated friction clutches. The headstock-end support plinth contained the drive system, this using a patented system that allowed the flat belt to be moved from pulley to pulley by means of sliding belt-guide arms - a method also used on some Schaublin lathes of the same era. The final drive to the headstock spindle was a 1.25-inch-wide flat belt. Amusingly, the recommended motor power was just 0.25 h.p. - today, a motor of that size would barely drag the spindle round at the slowest speed.
While lathes with an "F" designation were fitted with "friction power feeds", a cheaper version was also available, the "P" - standing for "plain" - this model lacking the power-feed apron but also offered in both 9- and 10-inch swing versions with screwcutting by either changewheels or quick-change box. Bench lathes were also listed, the Model "SP" being a backgeared type with screwcutting by changewheels and power sliding and surfacing feeds from the same type of apron as used on the "F". The spindle on this model was increased in size to take 1-inch capacity collets and the drive, by flat belt over a 3-cone pulley, arranged to come from an integral, rear-mounted countershaft. Confusingly, the next models in the range, all bench-mounted machines, used the same model designations as the underdrive types with, again, "F" when fitted with power feeds and "P" when without. The bench type could, however, be supplied on cast-iron standards - simple legs - though in the two catalogues far discovered, 1937 and 1940, these are not illustrated.
For the more impecunious customer, Brown also offered their "Dandy" range of bench lathes with plain bronze headstock bearings. The most expensive was the Model "SP Dandy" with screwcutting by changewheels, a one-inch collet capacity, a built-on, 3-speed countershaft using a flat belt - but no power-feed apron. The "F Dandy" was another 9-inch model, this retaining the power-feed apron but being supplied with a separate countershaft for wall or ceiling mounting. Another drive system offered for some models was an overhead type, similar to that used on several early Sheldon lathes.
The full range - as it was in 1937 - consisted of lathes marketed as "Brown" in underdrive 9 and 10-inch sizes with screwcutting gearboxes, the Types P, F, SP and SF, together with 9 and 10-inch versions with screwcutting by changewheels, the Types P, F, SP and SF. A complete, parallel range was offered in bench form that used identical model designations - and every lathe was available with between-centres capacities of 16, 22, 28, 40 and 76 inches. The cheaper "Dandy" range, again, duplicated all the foregoing but, as mentioned, with plain bronze rather than roller bearing headstock spindles.
By 1940, some changes had been made, with the S and SF having a modified gearbox: the lower selector changed from a horizontal sliding type to 3-position quadrant operation, and a separate shaft added to drive the sliding and surfacing feeds. As a consequence, the apron was also redesigned to be deeper, and the power sliding and surfacing engagement mechanism was changed to a more easily operated type using a quadrant selector and eccentric engagement lever. The full range of Brown and Dandy lathes made during the late 1940s can be seen in the 1937 and 1940 catalogues. With war threatening and the likelihood of increased demand for production lathes, the Company added at least one capstan lathe to its range: the Type TLL. This was a straightforward conversion of an existing engine lathe into a simple, hand-operated machine and intended for economical use in a small shop dealing with sub-contract work or engaged in the mass production of straightforward components.
Should you have a "Brown" or "Dandy" lathe (just two are known) - or one that resembles them - the writer would be interested to hear from you--continued on Pages  2,  3,  4  and  5.
1937 Brown Model F 10-inch  on an underdrive stand with a quick-change screwcutting and feeds gearbox (horizontal sliding second selector) and power-feed apron.
Brown Model P photographs here
1940 Brown Model S and SF with a modified screwcutting gearbox
with a quadrant second selector and separate power-feed shaft
1937 Brown 10-inch lathe Model SP with 1-inch collet capacity and a built-on countershaft unit
1940 Dandy Model F 10-inch lathe with plain spindle bearings and a  friction-drive power-feed apron
A post-1937 long-bed Brown with the late-type gearbox with quadrant second lever but of an unknown model type as  the apron appears to be a third type with a quadrant lever to select the feed direction but a screw-in clinch to engage it
A "Dandy" lathe for bench mounting - this  model lacks the full screwcutting gearbox and  power cross feed and has a plain bearing headstock
"Dandy" saddle and compound slide rest assembly - identical to that on the "Brown"
A "Dandy" overhead countershaft assembly - as found on the "Brown" and also lathes made in the Chicago Trade School
Restoration of the "Dandy" in progress
Brown & Dandy Catalog 1940   Dandy Catalog 1940   Model P Photographs
