Home Machine Tool Archive Machine Tools For Sale Email Tony@lathes.co.uk
Joinville Lathe - South Bend 9-inch Copy Blomqvist - Boxford - Hercus - Purcell - Sheraton - Joinville. Sanches Blanes - Smart & Brown - Storebro Stands & Drive Systems Headstock Details Carriage Assembly Screwcutting In the Factory 9-Inch Home Page South Bend Home Page 9-inch Clones Original 1934 9-inch Model 5 Accessories
Usina Metalúgica Joinville was a foundry and toolmaking business established in 1893 by Otto Bennack and concentrated mainly on parts for the railroad industry and farming tools. The company remained in his hands until the Second World War when, because of his German connections, he was forced to sell. At some point during the 1940s a South Bend lathe was acquired as a master pattern and production stated of a straightforward copy - the donor machine (based on the appearance of the bed feet and other details) being of 1940 vintage. The only significant modification made to the first production examples was a change from a V to a flat rear bedway - though soon afterwards a radial alteration was made when the headstock was modified to accept a larger bore spindle (0.826") running in parallel-bore, plain bronze spindle bearings held in conical housings by serrated screwed rings with adjustment by compression nuts. Later changes included a full-length cross slide carrying a single length-wise T slot, extra-wide bed feet and an entirely different and simpler design of apron with a single vertical lever to select and engage power cross feed. Although driven by a key riding in a slotted leadscrew, as on the South Bend original, on the Joinville the apron mechanism was not used to provide a geared-down sliding feed along the bed - this being left to the screwcutting gearbox and leadscrew. Development of the lathe continued during the 1950s and 1960s resulting, in the late 1960s, in the Model TM-127, a more angular machine, rather on the lines of a late-model Boxford and with the same type of taper-roller bearing headstock. This model continued to be available into the 1970s, being superseded by the types 217R and TM127, both of which were still able to accept many parts from earlier types. Joinville was eventually acquired by Romi (which still designs and manufactures metal-cutting machines) with manufacture of lathes passing to another company (Riosulense) who, by the late 1980s, were suffering (like all other makers of small lathes) from an influx of cheap Chinese machines and were forced to close. If any reader has details of this or other Joinville machine tools, or access to any of the company's sales and technical literature, the writer would be pleased to hear from them..
Brazil was a country that used both inch and metric measurements in engineering and the screwcutting box on the Joinville was arranged for English-pitch threads. The screwcutting plate on the changewheel cover was engraved with metric conversion charts and lists of associated translation gears.
The larger-than-original spindle bore and the tumble-reverse gears
Comprehensive screwcutting chart on the changewheel cover. Like the South Bend original this could not be locked shut nor did it have an inner safety guard.
The top slide is held to the cross slide using the standard arrangement of pins pushing screwed in from each side but it was not T slotted for a toolholder - instead the present owner has fitted a solid post to carry a single toolholder split through one face and so easily adjustable by its clamp bolt. This arrangement, used on the Drummond and Myford M Type lathes, is known in Britain as a "Norman Patent" toolholder. To the rear of the top-slide's location a single T slot is provided, running front to back along the centre line. The micrometer dials are larger than the South Bend originals and, with their knurled edges and ability to be zeroed, closely resemble those used on the Boxford clone.
The end of the leadscrew carries a useful handwheel - though this is an owner's modification.
