Ready for dispatch. A particularly interesting picture that can be dated to 1934 showing around one hundred and fifty Model 15 (Type 405 lathes) - the very first version of the well-known and very popular 9-inch "Workshop" series.
A row of 25 lathes (at the time the standard batch build number) under assembly. These are 9-inch "Workshop" machines each with a build sheet hanging from the tailstock end of its bed. Although the room would have been cleaned and tidied for the photograph it is still possible to spot backgear covers on the floor and, on the nearest lathe, a spring-bottom oil
Not all 9-inch types, but a vast array of tailstocks ready for dispatch to the build department.
Beds for 9-inch lathes
Six headstock casting being gang milled at the same time
Capstan lathes, driven by line-shafting, machining countershaft pulleys
A row of gear-hobbing machines
A view of the general machine shop, almost certainly taken in the early 1920s
