E-MAIL   tony@lathes.co.uk
Murad Antarctica "Beta" Lathe  page 1 /page 3 / page 4 / next page
Murad Home Page    Murad BORMILATHE   Murad CADET    Murad Capstan
Memories of Murad   Bronson Motor    Bormilathe Photographs   The Bormilathe in Use
Murad Factory   Murad Car   Other Products
This very original Murad Antarctica Model "Beta" lathe (on its heavy cast-iron mounting tray) shows little sign of use and may well be the best-preserved example in existence.
More on the Antarctica here
The Alpha and Beta were both designed for bench mounting, but with the Beta benefiting from the effect of being bolted to a heavy, very rigid, distortion-resistant "three-foot" cast-iron tray.
This early example of the Murad Antarctica lathe has six spindle speeds from 39 to 870 rpm. This was later increased to 12 by usual expedient of using a double-size pulley on the motor shaft together with matching larger pulleys on the countershaft; each model had its own speed range, arranged (on later models) as follows: 39 to 1300 rpm for the Alpha, 39 to 2000 rpm for the Beta and a very useful 39 to 2520 rpm for the Gamma.
The double-wall apron and generously-long saddle were both heavily constructed (and increased in size on later models); all shafts in the apron were supported in double bearings and the hand-feed action driven through triple reduction gears running in an oil bath. The top and cross slide feed screws were of Acme form and carried spring-loaded zeroing micrometer dials.
Murad Antarctica "Beta" Lathe page 2 / page 3 / next page
