LORCH - Early Precision Bench Lathe
      Lorch Home Page    Newer Accessories Page 2    Newer Accessories Page 3
Toolmakers' Plain AV1-K   Precision Plain: LLS, LLV  &  KD50    Toolmakers': LLR(G)N,  AVR(G) &  BVIR(G)
Toolmaker's Screwcutting  AVI-L   Precision Screwcutting  B27LZ
Lorch dividing apparatus for watchmakers' lathes
Toolmakers' Miniature: LAN, LLN & LLPN   Toolmakers': AV, AVI & AVII
Lorch COLLETS
Toolmakers': BVII,  C,  B,  BVI & Chase Screwcutting   Larger Screwcutting Lathes D27 & BIIZ
Earlier Lathes for Production Work      Short-bed Lathes
LAS & LL-K Precision
      Post 1950 Accessories      Pre 1950 Accessories   Thread Chasing Lathes    Optical Thread Chasing
More information about Lorch Lathes is contained in various Sales Brochures; click HERE for details.
Manufactured between 1880 and 1900 this lathe was intended to be used for work with larger clocks and instruments - exactly along the lines of American precision bench lathes such as those made by  Stark (the originators in 1862), the American Watch Tool Company, B.C. Ames, Wade, Pratt & Whitney, Rivett, Cataract, Hardinge, Elgin, Hjorth, Potter and Sloan & Chace.
Of 90 mm (3.5-inch) centre height the lathe had a 24-inch long bevelled-edge bed, a No. 1 Morse taper tailstock spindle and several distinctive features: "90-degree" ways to the top slide; a rack-and-pinion lever-action tailstock assembly built as an integral part of the unit; 6 screws firmly holding the end plate on to the cross slide; the top-slide T slot sitting in a section raised above the top surface (in a manner similar to that used by Pratt & Whitney); a T-slot let into the back of the cross slide; flat handles to the slide-rest; hand-rest screw locks and rather small diameter headstock bearings with a spindle that lacks a mounting thread but with the capacity to accept 15mm Boley collets. In traditional fashion for this class of lathe the headstock spindle and bearings were, like those in a watchmaker's lathe, hardened, ground and lapped to as perfect finish as could be obtained.
