Klopp Shapers - Page e
Klopp Catalogues  Comprehensive Shaper Instruction Book
Klopp Shapers Home Page
Controls: Model 800 friction -drive type
Klopp shaper rocker gear -  this was formed as a single unit integral with the main bearing of the machine (the column bush)
Speed-change gearbox models 625, 725  and 850. On all the larger machines, a high-pressure pump delivered oil not only to the gearbox but also the rocker gear,, rocker arm andr am slideways
Underside of the ram from one of the larger Klopp shapers - light to reduce the effect of its mass at higher stroke rates yet at the same time well braced  for strength by internal ribbing
Rocker arm: the unit used to convert rotary motion into the rectilinear alternating movement necessary to drive the ram
Klopp Model 300 Shaper as manufactured during the 1950s and 1960s.
Klopp Shapers - Germany
