Home    Machine Tool Archive    Lathes for Sale
Hendey Factory Tour - Machine Inspection & Testing
Drawing Office  Pattern Making  Foundry  Machining  Planing & Milling  Grinding  Heat Treatment
Assembly Process  Assembly Floor  Parts Inspection  Laboratory  Machine Inspection
Hendey Home Page  Works Tour Home Page  Power House  Toolroom  Dispatch
A finished lathe cutting a thread to check the accuracy of leadscrew and drive chain assembly. The finished thread was then inspected in the laboratory using specialist measuring equipment.
Alignment test on faceplate and cross slide
Headstock and tailstock centre-line test
A special tapered-end test bar was used to check the alignment of the headstock spindle
