Home    Machine Tool Archive    Lathes for Sale
Hendey Factory Tour - Laboratory
Drawing Office  Pattern Making  Foundry  Machining  Planing & Milling  Grinding  Heat Treatment
Assembly Process  Assembly Floor  Parts Inspection  Laboratory  Machine Inspection
Hendey Home Page  Works Tour Home Page  Power House  Toolroom  Dispatch
George Mills, a veteran employee with 48 years of service and long-time head of the Hendey laboratory, is seen testing the pitch accuracy of a sample screw generated in a lathe. The laboratory was not only guardian of mechanical standards but also undertook metallurgical, chemical and physical analysis of all materials used in the company's products.
George Mills testing the accuracy of a leadscrew's thread pitch using  precision end-rods calibrated by the U.S. Bureau of Standards
Use a Scleroscope (type D) to measure the hardness of a foundry-sample, gray-iron bar.
The Scleroscope was one of the first "non-marking" hardness-testing instruments and introduced circa 1905 by the Shore Instrument Mfg Company Ltd, of New York. It used a diamond tipped "hammer", held within a glass-fronted tube, that fell, from a height of 10 inches, onto a test specimen. The rebound of the hammer was measured on a graduated scale of "Shore" units each divided into 100 parts that, provide (in effect), a comparison with the rebound that might be expected from hardened high-carbon steel.
The hardness reading was really an expression of the material's elasticity and, as such, could be affected by the sample's mass, surface smoothness, depth and contour. Unlike many other methods of hardness testing a Scleroscope unit (in normal use) left only the slightest mark on the material under test. However, if further investigation was required the sample had to be turned so that the hammer fell on a new site; hitting the original impact point caused a higher bounce due to the slight work hardening from the first blow.
Two models were offered: the simple "C" with graduations to 140 that required the operator to estimate the rebound by eye and the more sophisticated Model "D"; this latter type was scaled to 120 and caused the hammer to strike a lever attached to a dial gage that saved the reading. The measurement symbol for a Scleroscope tester is "HS"
