Home    Machine Tool Archive    Lathes for Sale
Hendey Factory Tour - Planing & Milling
Drawing Office  Pattern Making  Foundry  Machining  Planing & Milling  Grinding  Heat Treatment
Assembly Process  Assembly Floor  Parts Inspection  Laboratory  Machine Inspection
Hendey Home Page  Works Tour Home Page  Power House  Toolroom  Dispatch
From the foundry, after fettling and cleaning, all larger castings that required a flat surface were taken first to the Planing and Milling floor. A 10-ton travelling crane was used to load and unload parts from a mixture of planers, plano-millers, vertical and horizontal millers and horizontal borers.
A 30-foot table Gray "plano-miller" with four powered heads being used to machine two parallel rows of lathe beds at one setting.
The main column of a Hendey 12-inch shaper being bored on a Giddings & Lewis Horizontal boring mill
Cast-iron lathe pedestals  on an Ingersoll Plano-miller - in effect a large planer fitted with two vertical and two side-mounted powered milling heads
View of the planing, heavy milling and boring floor. Judging by the number of un-machined castings stacked up behind the tooling rack in the foreground, the shop was working flat out
A pair of Kearney & Trecker "Milwaukee"  Model K vertical millers machining screwcutting gearbox components
