Walram Lathe Fine-feed and Speed-varying Attachment
Copies of the Maker's Literature, Screwcutting Charts, etc. are available
More Round Bed Illustrations    Working on a Round Bed
Rare 4" Drummond Flat Bed   Little Goliath
Drummond Home Page    EARLY 31/2" Drummond    Larger Drummonds   Admiralty Model
1925 M Type   Early Original 3
1/2"   1912 31/2" B Type  1921 M Type  Headstock Comparison
  M-Type Photo Essay    The First Drummond Lathe   Still in Use   Round bed Backgears  Walram
Literature for Drummond lathes, gear shapers and other machine tools is available. Email for details
A stage beyond the usual third-party backgear systems sold for the Round bed (and probably designed for use on a variety of lathes) the ingenious Walram attachment was bolted to the end of the headstock casting and driven from the normal countershaft by flat belt. The unit, which allowed the spindle to be driven through either reduction or step-up gearing, also provided a means of powering the leadscrew and would have been able to generate an ultra-fine carriage feed. The latter was achieved by means of an additional compound reduction gear train where two gear, one large and one small, are pinned together on a common shaft. Normally the Round Bed (like most other lathes) would have been able to accommodate only two compounds but, with the Walram in place, three could be assembled. For example: with gears sets of 21/40, 20/63 and 20/64 in place a feed rate equal to 192 T.P.I. could be generated, far finer than that available with the standard set-up
As the Walram employed the left-hand threading bracket as part of its mounting it could also be used to generate left-hand pitches and so was able to be left in place for all normal work..
The Walram in use to provide a left-hand threading drive to the leadscrew. It could also be assembled to give an ultra-fine feed by means of an additional compound reduction where two gears--one large and one small--are pinned together on a common shaft. Normally the Round bed would have been limited to two such assemblies but with the Walram in place three could be built.
The Walram arranged to drive the headstock spindle.
The basic Walram unit
