Myford M-Type Countershafts
Copies of the Maker's Literature, Screwcutting Charts, etc. are available
Drummond Home Page   EARLY 3 1/2" Drummond   Larger Drummonds   Round Bed Drummond
Rare 4" Drummond Flat Bed   Headstock Comparison   Admiralty Model   M-Type Photo Essay
Early Original 31/2"    1912 31/2" B Type   1921 M Type   1925 M  Type     Little Goliath
    The First Drummond Lathe   Still in Use    Round bed Backgears   Walram
A set of photographs showing details of the very heavy, rear-mounted countershafts fitted, with some modifications and differences, to stand-mounted M Types from 1942 until approximately 1951. A picture of the bench countershaft assembly can be seen here.
A substantial cast-iron over-centre tensioning arm, with a right and left-hand threaded adjuster to allow the belt tension to be precisely set. The bearings were plain but held within ingeniously-designed housings where the points of two opposing and adjustable screws pressed into countersinks on either side of each bearing and both held them and allowed a degree of elf-alignment. This type of countershaft assembly  was also used (from 1935) on the American Atlas 10-inch lathe (though with Hyatt roller bearings) and later on the Australian-built Hercus copy of the South Send 9-inch.
The countershaft was enormously long and heavy and pivoted from a triangular plate bolted to the rear of the leg at the headstock-end of the lathe.
The motor plate was supported on an adjustable rod that allowed the motor-to-countershaft belt tension to be set. Some lathes had their motor mounted underneath the plate and the adjuster arm connected to a lug on the countershaft itself.
A view with the tensioning arm removed.
Both the two-step countershaft pulley and 3-step headstock-drive pulley were in cast iron the extra inertia of which helped to smooth out the drive from the commonly-fitted single-phase motor.
Spindle-speed chart riveted to the inside face of the countershaft.
Some lathes carried a second plate listing the speeds available with the alternative 950 rpm motor.
