Home       Machine Tool Archive       Machine Tools For Sale & Wanted
Drummond "Little Goliath"
Showing some of the modifications introduced during that year
Copies of the Maker's Literature, Screwcutting Charts, etc. are available
Drummond Home Page   EARLY 3 1/2" Drummond
    Larger Drummonds
Round Bed Drummond   Rare 4" Drummond Flat Bed   Still in Use
Early Original 31/2"    1912 31/2" B Type   1921 M Type  1925 M Type   Round bed Backgears
Headstock Comparison
Admiralty Model   M-Type Photo Essay    The First Drummond Lathe   Walram
The hardened centre at the back of the spindle bore against an adjustable tube secured by a single square-headed bolt; this system was a variation on a method more commonly found on both inexpensive and better quality lathes from mid to late 1800s.
A flat brass plate with degree calibrations was trapped between the top slide and cross slide; however, because the plate was not screwed down but only just turned over along its inside edge to locate it, as the top slide was swivelled, or the clamping bolt tightened, the plate moved and the reading changed.
The tailstock made do with just a simple (but very effective) lever-action control for the barrel with the various pivot points provided by ordinary split pins.
Both the carriage assembly and tailstock were bolted to the flat-topped bed by two bolts on their underside, one at the front and one at the rear.
Front tailstock bed clamp
Home       Machine Tool Archive       Lathes for Sale
    Larger Drummonds
M Type   Early Original 31/2"    1912 31/2" B Type
