E-MAIL tony@lathes.co.uk
Machine Tool Manuals   Machine Tool Catalogues  Belts
Rockwell Delta 10-inch Lathe
Carriage, Headstock, Gearbox
10" Drive Systems
    Delta 10" lathe     Delta 11" lathe    Delta 14" lathe
Carriage assembly showing over-centre power-feed engagement lever the tension of which could be adjusted as the machine ran.
Headstock assembly with twin V belt drive and a usefully large gear on the end of the spindle to even out wear over the very long-term
Two-lever Screwcutting Gearbox
Rockwell Delta 10"
10" Drive Systems
