E-MAIL   tony@lathes.co.uk
Churchill-Redman CUB Lathe
Cub Capstan Model & Capacity Chart   Mk. 1 & Mk. 2 Cub
Mk. 2 Cub Headstock   Mk. 2 Carriage & Changewheels
An Operator's Handbook with Spares List (as detailed sectional drawings) is available for
the later versions of this lathe.
SOUGHT by the writer: sale or loan of literature for the Mk. 1 & Mk. 2 Churchill Cub
Built in England by Churchill Redman Ltd. in both Halifax (Yorkshire) and Scotswood (Tyne and Wear), the 6" x 20" (later 6.5" x 24") gap-bed Cub lathe was built (as far as evidence from date-coded catalogues indicates) from 1933 until the early 1960s. The Scotswood plant made a number of different centre lathes, some of which were destined for Indian Railways and purchased through the Crown Agents, during the 1950s assembly of the Cub was entrusted to Jim Kennedy, a foreman who had originally worked on the lathe in the Halifax plant. In August 1957 the name of the Company changed to "Churchill-Gear Machines Ltd." and a move was made to a new factory across the river at Blaydon-on-Tyne. Even though the name had been changed the firm continued trading under its original name and the factory signs in Halifax were not changed. Unfortunately this promising development was followed by a large-scale redundancy in early 1958 and this, together with increasingly stiff competition from Colchester and their mass-produced Student and Master models, would have signalled the end of the Cub's life.
Although both the registration of the original design, and patents were applied for in the early 1930s it was not until February 3rd 1948 (and the introduction of an almost entirely different model) that anything seems to have come of this with two Design Numbers (843,456 and 844,892) together with a Patent (597764), being granted - with the latter concerning an ingenious method of selecting spindle speeds. Being compact, but having a generous capacity for its size, the lathe quickly became popular with training establishments, commercial engineering companies and the Armed Services with many examples supplied to the Royal Navy for use in submarines during WW2. As a consequence of its widespread adoption by official bodies many, still in lightly-used condition, eventually found their way onto the surplus market and are still in use today.
Four versions were produced that we shall call the Mk. 1, Mk.1a, Mk. 2 and Mk. 3: these are all very easily distinguishable from each other: the Mark 1 can be recognised by a bed and headstock as one with the headstock of square appearance with all the control levers for speeds, threads and the selection of power feeds being straight tapered arms with acorn-shaped ends: the Mk. 1a appears to have been mechanically identical but fitted with distinctive  "bent" control levers; the Mk. 2, a machine with a more rounded styling, had bed and headstock formed separately and was fitted with neat (if rather large and smooth-faced) full-circle "hexagonal" controls (that replaced all the levers); the Mk. 3 employed just two headstock-mounted rotary controls and three octagonal knobs on the gearbox.
On its introduction the Cub's closest direct competitors were probably the geared-head 4
1/2-inch Denham Junior and (rather old-fashioned) 5-inch flat-belt drive Colchester Bantam. It managed to outclass both of them by offering a centre height of 6-inches, 24 or 36 inches between centres, the ability to swing a piece of material 16 inches in diameter by 4-inches thick in the gap and a useful speed range (powered by a 3/4 h.p. 15000 r.p.m motor bolted to the back of the bed) of: 25, 44.5, 81, 142, 250 and 457 r.p.m.  As an alternative, and fitted with a more powerful motor and a change of pulleys, the speeds could be arranged to run from 50 to a more useful top peed of 900 r.p.m. Drive to the all-geared headstock was by twin (and then still novel) V-belts - thought at the time these were commonly referred to as "tex ropes" - with speed changes by the juxtaposition of two levers on the front face of the headstock. Much play was made by Churchill of the lathe's material specifications and heavy build, the inverted V-way bed and headstock were cast as one and, although strictly speaking the bed was not hardened, the cast iron (with the advertising puff of being described as "semi-steel") was to Brinell  200.  Whilst the two headstock layshafts with their nickel-chrome, 65-ton tensile  steel gears rotated on ball races the 9/16" bore main spindle was fitted with Timken taper roller bearings set up to absorb both radial and thrust loads. The gears ran in a simple splash oil bath (with a rather venerable vertical glass oil-level indicator on the front of the headstock) with the headstock cover, and guards over the changewheels and motor-to headstock drive belt, in cast aluminium.
Drive to the (oil-bath) three-speed screwcutting and feeds gearbox was by a train of conventional changewheels; however, instead of the expected externally-mounted tumbler to reverse the leadscrew and feed shaft an internal gear mechanism was neatly built (like a larger lathe) into the headstock where the fast-running gears benefited from a constant supply of lubricant. The leadscrew was used only for screwcutting (a lever was provided to disengage it from the feedbox) with the sliding and surfacing feeds being driven by a separate power shaft; the double-walled, oil-bath apron mounted a central push-pull button to select the feed (along the bed or across) and a screw-in handwheel to engage the drive through a cone-type friction clutch. On the Mk. 2 lathe the selector lever was changed to a flick-left-and-right type, but the cone clutch remained. The right-hand face of the apron was fitted as standard with a thread-dial indicator but, instead of a sight-glass that showed the state of the oil level at a glance, a simple flip-top oil cup was supplied that required the operator to open, check and top up as necessary.
The compound slide rest was fitted with taper gib strips, "balanced" handwheels and what were, for the time, decently-sized micrometer dials. Unfortunately the cross slide was of the short type, but at least with a stout, cast-iron cover at the back to protect the end of the feed-screw.
Early versions of the lathe have been found mounted on a pair of heavy-gauge, pressed-steel, all-welded legs complete with a chip tray whilst later variants were also available on "semi-cabinets" with a welded sheet-steel box structure at the headstock end of the bed and a simple leg, in cast iron or pressed steel, at the other.
Before dispatch from the works each Cub was run-in and the spindle bearings adjusted to eliminate the need for adjustment for "
a number of years">
Although a sound lathe by the end of World War Two the Cub was looking decidedly old-fashioned and, to address the situation, the Churchill company embarked on a complete redesign. The resulting Mk. 3 was not only more modern and powerful-looking but also incorporated numerous significant mechanical improvements that allowed the lathe almost another 20 years of life. The new model lathe was not only well engineered and but, although it was solidly constructed and weighed 1232 lbs/559 kg (as much as a Colchester Student/Clausing 13-inch) it was very compact and needed a floor space of only 5 by 2 feet. By the standards of the 1940s it had an excellent standard specification that built on what had come before: a neat, all-welded cabinet base housing the motor, its control gear and built-in coolant, the centre portion the electrical switchgear (and sometimes a drawer) and the right-hand side two drawers (one of which could be locked to hold the operator's personal belongings) and a cupboard: an oil-splash lubricated, all-geared taper-roller bearing headstock: a combined spindle clutch and brake: the sliding and surfacing feeds operated by a separate 5/8" diameter feed shaft: an oil-bath apron: a removable gap in the bed (that allowed material 17.5 inches in diameter and 4.375 inches thick to be turned) and a sealed, oil-immersed screw-cutting gearbox.  Versions manufactured in the late 1940s were offered with the option of a more modern-looking, neatly-constructed fabricated-steel cabinet stand with the left side containing the motor. The original finish - at least of the later models - appears to have been a rather dark shade of the standard "British machine-tool grey".
The same reasons that made the lathe appeal to sub-mariners should also attract the home-user today: a rugged build, generous centre height, enormous capacity in the gap, versatile performance, reasonable between-centres capacity, compact dimensions, a capacity to endure serious rates of metal removal - and all at a price well below that asked for modern machines of a similar size (if better specification) - the Colchester Bantam and Harrison M250, for example. Of particular interest to the amateur, who may have to transport his own machine and then install it in an inconveniently-sited workshop, is the ease with which all but the Mk. 1 Cub can be dismantled into its component parts; competent mechanics have been known to remove the tailstock, carriage, gearbox and headstock in about 15 minutes leaving a naked bed attached to a now easily-moved cabinet; the same job on Bantam or M250 will take the best part of an entire morning.
Continued below:
Churchill-Redman "Cub" Mk. 3 as supplied during the late 1940s and 1950s. The cam-action lever on the face of the apron engaged and disengaged the power feeds and was a considerable improvement on the slow-to operate screw-in-and-out knob used on earlier versions.
Continued:
Hand scraped until it was a perfect fit on the bed the separate headstock carried a 3/4" bore spindle supported in a pair of opposed Timken taper-roller bearings at the front and a roller bearing at the rear. The spindle nose appears to have been Churchill's own adaptation of the standard "Camlock" flange - but with 3/8" Allen screws instead of studs - and carried a No 3 Morse taper; Pratt Burnerd apparently retain a pattern of the Churchill mount and are able to supply new chucks with the proper fitting built in. All the gears had shaved teeth and were hobbed from nickel-chrome, heated-treated steel with the speed changes made by a single rotary control conveniently sited on the front face of the headstock. The other headstock shafts (as they had on the Mk. 1 and Mk. 2) revolved in ball races.
The standard drive system consisted of an under-slung 2-speed, 3-phase motor mounted on an adjustable plate (to allow for belt tensioning) that ran  at 960 and 1400 rpm and drove to the geared-headstock input pulley by two M-section V belts to give 12 spindle speeds in a range that, whilst it varied over the years, was typically 45 to 900 rpm on very early machines with some (probably those ordered for use in training establishments) with a much lower top speed of 400 rpm. Later machines were given a somewhat improved range (although the top speed was still a little slow) of: low-range 32, 60, 112, 190, 356 and 665 rpm and high-range 48, 90, 168, 285, 534 and 1000 rpm. In today's faster world, if the owner's work demands a higher top speed then it is unlikely that the roller-bearing headstock would protest (although the motor might) if the top speed were lifted to some 1500 rpm or so by using a larger pulley on the motor shaft. Not all machines however were fitted with the two-speed motor as both single-speed AC and DC units were available as options, the former likely to have been specified when used in a training role. When fitted with a single-speed motor 6 speeds were available with a choice of two ranges, either 48 to 1000 rpm or 32 to 665 rpm. The headstock input pulley incorporated a multi-plate disc clutch the design of which was improved in 1948 from machine number 16048
Ground-finished from a substantial and heavily cross-braced casting the massive bed carried double-Vee slideways, one for the saddle and one for the tailstock, and was fastened to its cabinet by four 3/8 Whitworth setscrews - but not shimmed or levelled in any way; a simple plain cardboard gasket was used to seal against coolant leaks into the cabinet whilst the detachable gap bridge was secured by four Allen screws.
The compound slide rest was fitted with proper taper-gib strips and large, zeroing micrometer dials. The top slide could be swivelled through 360 degrees and a steel 4-way tool post was mounted as standard.
The apron was of double-walled construction with an oil bath in the base with all the shafts, supported at each end, running in easily-replaced bronze bushes. Whilst the sliding and surfacing feeds were still selected by the same lever arrangement from the Mk. 2 (that was flicked left and right from its central, neutral position) they were now engaged and disengaged by a quick-action toggle lever whose action allowed the drive to be instantly released - a considerable improvement over previous slow-to-operate wind-in-and-out knob. The power feeds were also arranged to work through a spring-loaded safety clutch built into the drive shaft just before it entered the feed box; as before a thread-dial indicator was fitted as standard.
Screwcutting was taken care of by a 4 t.p.i. 7/8" in diameter leadscrew driven from an enclosed, splash-lubricated gearbox operated by two dials and capable of generating 30 pitches from 10 to 76 t.p.i. and 30 sliding feeds from 0.001" to 0.0076" per revolution of the spindle. Whilst the sales literature claimed that additional changewheels of 30t, 60t, 60t, 110t and 120t were provided with each machine to extend the threading range from 2.5 to 75 t.p.i. (and the  feeds from 0.001" to 0.030") an examination of machines in use appear to indicate that the original gear train (for a gearbox-equipped lathe) used a 30t drive gear, 110t idle gear and a 120t  gear on the gearbox input shaft. Stored outboard of the idler gear and gearbox input shaft were gears of 45t and 50t - but with no sign of the 60t gear. At extra cost an additional nine (unspecified) changewheels were available to generate metric pitches from 0.20 to 8.0 mm pitch. The surfacing feeds were set at the usefully fine rate of one-fifth those of the sliding.
Although the structure of the tailstock was entirely ordinary, the method employed to lock it to the bed was not: a handle (conveniently positioned at the top of the casting) was rotated in a horizontal plane and, through a captive nut, drove a system of levers that pivoted inside the tailstock body and drew up a locking plate firmly against the underside of the ways. Conventional parts of the tailstock included the set-over base, locked with two screws and the No. 3 Morse-taper barrel, fed by a screw and handwheel, with a travel of 3 inches, and self-eject for the centre.
Coolant was distributed from a gear pump attached to the rear of the bed below the headstock and driven by a V-belt from the rear of the headstock spindle. Cutting fluid was taken from a small tank in the cabinet and fed along a pipe inside the bed to an outlet union part way along it.
One interesting addition to the usual accessories (a taper-turning unit, large faceplates, collets and fixed and travelling steadies) was a 6-station self-indexing capstan slide attachment (with 6 inches of tool travel) that fitted in place of the tailstock yet left the standard carriage undisturbed. Once very popular this fitting allowed a small machine shop to gear up for short productions runs without having to find the space and money for a (at the time hard-to-find) small capstan lathe. Unusually, instead of being just bolted to the bed - as were the vast majority of similar capstan heads offered by competing companies -  this was a fully powered version, driven from the feed shaft, that turned the lathe into a unit capable of serious work.
Charles Churchill and Churchill Redman made (and also marketed in collaboration with other manufacturers) a wide variety of other machine tools including toolroom, automatic, heavy-duty, centre, hydraulic-profiling, surfacing and boring lathes; shaping  machines, Churchill-Cleveland hobbing machines and Churchill-Red Ring gear shavers.
If any reader can provide photographs, advertising catalogues or other literature and information relating to the very early models of the Cub, the author would be pleased to hear from you..
The Mk. 3 Cub, from the late 1940s, was offered with the option of modern-looking, neatly-constructed fabricated-steel cabinet stand with the left side containing the motor, the centre portion the electrical switchgear (and sometimes a drawer) and the right side two drawers (one of which could be locked to hold the operator's personal belongings) and a cupboard.
Early versions of the lathe, both Mk. 1 and Mk. 2 have been found mounted on heavy, pressed-steel legs and also on "semi-cabinets" - where a box structure of heavy-gauge pressed steel supported the headstock end of the bed and a simple leg, in cast iron or pressed steel, the other.
Home   Machine Tool Archive   Lathes for Sale   Millers & Grinders for Sale
An Operator's Handbook and Spares List (as detailed sectional drawings) are available for this lathe.
