E-MAIL Tony@lathes.co.uk "Quick-Change Swing Precision Lathe" Plain-Bearing Headstocks Ball-bearing Headstocks Compound Slides Accessories Turret Lathes Plain-bearing Bench Lathes Production Accessories Special Tailstocks Grinding Accessories Toolroom Lathe Milling Accessories Precision Drills Pinion Cutter Screwcutting & Power Feed Millers Cataract Equipped Workshop Late Stands Early Stands & Multiple Lathe Mounts History Designed by Mr. Franklin Hardinge and in production for the first time during World War 1 (1914 -1918) the fabulous Hardinge 9" x 28" "Cataract Quick Change Swing Precision Lathe" was a new departure for the company. The specification was excellent with a 21/32-inch diameter front headstock bearing and a hardened and ground 1.25" bore spindle; a full screwcutting gearbox drove a 1-inch diameter 6 tpi leadscrew with a separate powershaft for the standard-fit power sliding and surfacing (both engaged by friction clutches) with an automatic, precision-adjustable disengagement to the sliding feed; extremely long saddle wings - which overlapped the headstock by several inches - taper turning as standard, a 360 degree swivel top, twin-clamp tailstock and a useful swing-out rotating collet tray beneath the chip tray. The power feeds could be instantly changed through three rates by a separate control working through the gearbox input gears. |
