E-MAIL Tony@lathes.co.uk Cataract Home Ball-bearing Headstocks Compound Slides Accessories Precision Drills Plain-bearing Lathes Turret Lathes Production Accessories Cataract Equipped Workshop Special Tailstocks Grinding Accessories Milling Accessories Screwcutting & Power Feed Millers Toolroom Lathe Late Stands Early Stands & Multiple Lathe Mounts Pinion Cutter History The Cataract Pinion Cutter was designed for use in watch and clock factories where mass production of wheels (gear wheels) was required. In addition. at a time when almost any type of measuring instrument relied upon gears and not electronics, gear and pinion cutters were an essential adjunct to instrument and toolmakers of all kinds. |
E-MAIL Tony@lathes.co.uk Cataract Home Ball-bearing Headstocks Compound Slides Accessories Precision Drills Plain-bearing Lathes Turret Lathes Production Accessories Cataract Equipped Workshop Special Tailstocks Grinding Accessories Milling Accessories Screwcutting & Power Feed Millers Toolroom Lathe Late Stands Early Stands & Multiple Lathe Mounts Pinion Cutter |
