Home       Machine Tool Archive       Lathes for Sale
Atlas 6-inch Mk. 2 Lathe Additional Pictures
Page 2 of 2
Atlas 6" Home Page    6" Accessories   Atlas 9"   Atlas 10"    10" & 12" Accessories   10" Gearbox Details   Atlas Home  Pick-O-Matic Threading    Atlas Late Model 12"   Early Basic 10" Model
Atlas Home   Later Basic 10" Models   Atlas Factory   Sphere Clone   Halifax Clone   Utility Lathes
Catalog Covers   Metalcraft Model   Atlas Screw-Machine (capstan)
To tension the belt, in the absence of any means of  moving the motor, a simple adjustable jockey pulley (top left-hand corner of the picture) sliding on a stud, was fitted above the belt run. Unfortunately this "modern" method of engineering a headstock drive had the effect of reducing the number of spindle speeds from 16 to 8 but with a still-respectable range of 55 to 2300 rpm with the maker's recommended 1/3 hp 1725 rpm 60 cycle motor.
Swivelling Vertical Milling Slide M6-500/500A with built-in vice - this unit plugged into the fitting normally occupied by the top slide and was a smaller version of that available for the 10" lathe.
Overall Height 11
1/2"
Vertical Feed 1
3/4"
Vise Capacity 2"
Jaw Depth 3/4"
Jaw Width 2"
Another picture here.
