A series of pictures showing some parts of the Atlas plant at 1819--1919 North Pitcher Street, Kalamazoo, Michigan, in the USA. More illustrations can be found here. With both sets of pictures taken in either the 1930s or 1940s the Atlas photographs make an interesting comparison with those of the Hendey factory .
Lathe assembly benches circa 1933. In this picture 9-inch compound drive V-belt drive lathes are being put together, possibly in groups of twenty at a time, at individual work-stations. With manufacture of this model only underway for a year no production line had yet been installed and building lathes required the fetching and carrying of parts and the lifting away of complete units. Each workstation was illuminated by a single bulb.
By the time the first 10-inch lathes were in production a simple chain-driven assembly line had been installed. Note the "wall-of-glass" windows, a feature of many factories until the arrival of improved electric lighting.
Another view of the same early 10-inch lathe production line.
By 1936 the factory appears to have been a busy place with several production lines as well as stations where individual machines were built up on their cast iron stands
A Norton surface grinder being used to finish the bed-ways of a 9-inch lathe.
Around one thousand 9-inch lathe beds stored for seasoning before machining
A view captioned by Atlas as the "toolroom" showing tool-and-cutter grinders, universal grinders, shapers, milling machines and hand-fitting benches all rather close to each other.
