Atlas 9-inch "Utility" Lathe
Atlas Home Early 10" Basic Versions Late 10" Basic Versions Sphere Clone
Halifax Clone Atlas Factory Atlas 6" Atlas 6" Mk. 2 6" Accessories Atlas 9"
Atlas 10" Utility Lathes 10" & 12" Accessories 10" Gearbox Details
Pick-O-Matic Threading Atlas Late Model 12" Catalog Covers Metalcraft Model
Atlas Screw-Machine (capstan)
Unashamedly advertised as the "Utility" model bench lathe this rare 18-inches between centres machine, with a production run from around 1934 until 1938, retained the screwcutting facility of the better-specified lathes but had only 6 spindle speeds (202, 330, 530, 610, 1015 and 1625 rpm) obtained by the use of a 3-step pulley on the headstock and a double step pulley on the motor to countershaft drive.
On the original "918" version not only was no backgear was fitted but also a simple, 'non-swivelling' cross slide was specified. Two other 918 models were available: the 918A, which came with a complete set of changewheels to cut threads from 4 to 96 t.p.i. and the 918B, which had, in addition, a graduated, swivelling compound slide rest. .
